zc702 trd design issue for tpg to hdmiout
Dear,
Is it possible to make tpg ip directly connect to hdmiout module without via vdma?
I tried to modify zc702 trd example to make tpg directly connect to hdmiout, but failed, why?
Tags (2)
Re: zc702 trd design issue for tpg to hdmiout
Typically, if a video IP has a master AXI4-Stream output and another video IP has a slave AXI4-Stream input, then the two IP can be connected together as long as both of the AXI4-Stream interfaces follow the "Video over AXI4-Stream" protocol defined by Xilinx in UG934.
https://www.xilinx.com/support/documentation/ip_documentation/axi_videoip/v1_0/ug934_axi_videoIP.pdf
It is the responsibility of the user to verify that connecting the two IP is appropriate.  In this case it's likely that the "hdmiout" can accept a video stream from the TPG.
As for why your modifications failed.  I have no idea.  You didn't provided any information.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Hi p.ching.kuang@gmail.com,
Did the reply from @tedbooth helped?
If your question is answered or your issue is solved, please mark the response which helped as solution (when logged in, click on the "accept as solution" button below the reply)
Best Regards,
Florent
Xilinx Community Forums Moderator
Florent
