64bit datawidth fot V6 GTX
V6 GTX will support 64bit datawidth?
For PCIE Gen3,if 32bit,the pipe clk needs at least 250MHz.I think it is impossible to archieve it unless 64bit datawidth.
Re: 64bit datawidth fot V6 GTX
PCI Gen3 runs at 8.0 Gb/s with 128B/130B encoding.  This is not possible with Virtex-6 GTX Transceivers.
GTH is ok?
The Virtex-6 GTH has a limited operating range as defined in the data sheet.  8.0 Gb/s is outside of that range.
So,not any xilinx device can work at PCIE Gen3(8Gb/s) ?
