Observer vinod_1987
Aurora 8b/10b design example
        I'm using Aurora 8b/10b ip core, ISE 14.7, virtex 5 Fpga board.
       I want test the loopback of Aurora 8b/10b IP core (Near end PCS) on single board. (virtex 5 ). I have generated Aurora Ip core using core generator with lane = 1, lane rate 3.125 Gbps, GTRefclk= 156.25 Mhz.
issue is - My virtex 5 board as 100Mhz clock (pin number H17). how to convert on board 100Mhz clk to my design(Aurora) GTrefclk 156.25 Mhz.
Community Manager
Community Manager
Re: Aurora 8b/10b design example
Please refer to http://www.xilinx.com/products/boards/ml505/ml505_10.1_3_1/docs/ml505_aurora.pdf
Community Manager
Community Manager
Check this XAPP targeting for KC705 board it may help
http://www.xilinx.com/support/documentation/application_notes/xapp1193-aurora-8b10b-on-kc705.pdf
For clocking you need to use PLL . Check the Aurora product guide for detail
Thanks and Regards
Balkrishan
Observer vinod_1987
thank you Smarell.
