code_slave
Boolean optimisation
Would there be any advantage between using either of  the following two terms as regards optimisation?
o <= z xor (x and (y xor z))
o <=(x and y)xor ((not x) and z)
CS
rcingham
What FPGA family?
What version of tools?
"If it don't work in simulation, it won't work on the board."
eilert
since you only have three inputs, everything should collapse into one LUT.
The smallest LUTs (physically) in Xilinx FPGAs have 4 inputs.
Actual Xilinx FPGA Families have 6-input LUTs.
So, when you synthesize these code lines and take a look at the Technology Schematic
there should be LUT3 symbols and the number behind these should be the same, if the two lines are truly equivalent expressions.
e.g. LUT3_B1 <- this hexadecimal number is derived from the truth table of the LUT
Have a nice synthesis
  Eilert
bassman59
Historian
Historian
Write code that makes sense to a human who has to read it, and let the tools optimize it.
code_slave
Sorry the first  question was trashed due to login timeout
FPGA XUPV5-LX110T
tool ISE 14.2
