iamadog3333
Can not readback from opb HWICAP in XUPV2P--the readback status does not show DONE!
Hi guys,
   I found a problem when using OPB-HWICAP.
   I builded a basic system containing a Softprocessor and the system's frequency was 50Mhz. HWICAP can works at 66Mhz.
In the bitgen.ut file, I set "-g M0Pin:PULLUP -g M1Pin:PULLUP -g M2Pin:PULLUP".
   Then I run "xhwicap_low_level_example.c" from the HWICAP's driver in IDE. It contains an example of how to use the low-
level macros and functions of the XHwIcap driver.
   When I run this file:
   XHwIcap_mSetBram(BaseAddress, Index, ReadId[Index]) excuted. Write bitstream to bram OK.
   XHwIcap_mSetSizeReg(BaseAddress, (XHI_EX_BITSTREAM_LENGTH<<2) -1) excuted. Write to the SIZE register OK.
   XHwIcap_mSetOffsetReg(BaseAddress, 0) excuted. Write to the OFFSET register OK.
   XHwIcap_mSetRncReg(BaseAddress, 0) excuted. Write a 0 to the RNC,begin transfer from the bram to the ICAP,OK.
   Waited until (XHwIcap_mGetDoneReg(BaseAddress) != 0), means DONE and transfer completed.
   XHwIcap_mSetSizeReg(BaseAddress, (XHI_EX_ONE_WORD<<2)-1) excuted, Write to the SIZE register OK.
   XHwIcap_mSetOffsetReg(BaseAddress, XHI_EX_BITSTREAM_LENGTH) excuted, Write to the OFFSET register OK.
   XHwIcap_mSetRncReg(BaseAddress, 1) excuted, initialize readback from the ICAP to the bram,OK.
   Wait until (XHwIcap_mGetDoneReg(BaseAddress) != 0)...
   Then comes the problem, the status register's DONE does not become "1" !!!
while (XHwIcap_mGetDoneReg(BaseAddress) == 0)
        Retries++;
        if (Retries > XHI_EX_MAX_RETRIES)  //I even changed the XHI_EX_MAX_RETRIES from 100 to 10000.
        {                                  //But it still time out!!!
             * Waited to long. Exit with error.
             print("waited too long!!!!\n");
            return XST_FAILURE;
The opb_xhwicap's version is 10_0_a. The chip is Virtex II Pro 30 V2P30 in XUP V2P30.
Question1:What's the prolem? Why HWICAP is busy so long?
Question2:Is 50Mhz too fast?
Question2:When use XHwIcap_mSetRncReg(BaseAddress, 0) writing a 0 to the RNC,begin transfer from the bram to the ICAP.
But the ICAP put the bram data to where in device? I did not even assign a place in the Chip!
Anyone has advice? Thank you ahead.
Tags (3)
iamadog3333
The problem was solved! The main reason is some setting in bitgen.ut was wrong.I use the bitgen.ut file as follows, then it works! -g DebugBitstream:No -g Binary:no -g CRC:Enable -g ConfigRate:4 -g CclkPin:PullUp -g M0Pin:PullUp -g M1Pin:PullUp -g M2Pin:PullUp -g ProgPin:PullUp -g DonePin:PullUp -g PowerdownPin:PullUp -g TckPin:PullUp -g TdiPin:PullUp -g TdoPin:PullNone -g TmsPin:PullUp -g UnusedPin:PullDown -g UserID:0xFFFFFFFF -g DCMShutdown:Disable -g DisableBandgap:No -g DCIUpdateMode:AsRequired -g StartUpClk:CClk -g DONE_cycle:4 -g GTS_cycle:5 -g GWE_cycle:6 -g LCK_cycle:NoWait -g Match_cycle:Auto -g Security:None -g Persist:No -l -m -g ReadBack -g DonePipe:No -g DriveDone:No -g Encrypt:No HWICAP's IP version is 1.00b, the driver's version is 1.00a. For more information: iamadog3333@163.com Kudos! Thanks!
iamadog3333
