brunocavagna
DDR2 MEMORY CONTROLLER - UCF ERROR FROM MIG
Hi all,
I generate a DDR2  MEMORY CONTROLLER  with MIG 3.61. During mapping in ISE 12.4, I have a really odd error that I don't understand.
ERROR:Place:864 - Incompatible IOB's are locked to the same bank 27
   Conflicting IO Standards are:
   IO Standard 1: Name = SSTL18_II, VREF = NR, VCCO = 1.80, TERM = NONE, DIR =
   OUTPUT, DRIVE_STR = NR
   List of locked IOB's:
       DDR2_DM[0]
       DDR2_DM[1]
       DDR2_ADDR[7]
       DDR2_CKE
       DDR2_ADDR[11]
   IO Standard 2: Name = LVDS_25, VREF = NR, VCCO = 2.50, TERM = NONE, DIR =
   BIDIR, DRIVE_STR = NR
       DDR2_DQS_N[0]
       DDR2_DQS_N[1]
       DDR2_DQS_P[0]
       DDR2_DQS_P[1]
   These IO Standards are incompatible due to VCCO mismatch.
I understand the error, you cannot have a SSTL18 and a LVDS_25 IO  in a the same IO bank. And I agree!
But, have a look to the UCF file with the IO contstaints .The UCF is taken from MIG that has not been modified.
NET  "ddr2_dq[*]"                               IOSTANDARD = SSTL18_II_T_DCI;
NET  "ddr2_dqs_p[*]"                            IOSTANDARD = DIFF_SSTL18_II_T_DCI;
NET  "ddr2_dqs_n[*]"                            IOSTANDARD = DIFF_SSTL18_II_T_DCI;
My problem is ddr2_dgs_p/n IOs are defined as a DIFF_SSTL18_II_T_DC and not LVDS_25.
Does anyone has an idea about this issue?
Bruno
eteam00
Instructor
Instructor
Your analysis of the problem is absolutely correct.
I've never dealt with this problem, so I'm guessing on these suggestions:
  • Try Project > Cleanup Project Files
  • Search for unexpected or extraneous .UCF files in your project folders, and toss (or rename) the dodgy ones.
-- Bob Elkind
SIGNATURE:
Summary:
brunocavagna
I remove unused UCF files and I clean up Project filesas you suggest but the same errors remain.
mcgett
It appears the UCF file that you are editing is not being used by your ISE project.  Check your report files to see which UCF it is actually reading.
