Visitor marahman
Designs that maximizes (80%)slice and LUT usage, Virtex -5 XCVFX70T
I have to implement a design that uses at least 80% of the slices available on V5. What is the best way to achieved it? Is there an example design available that uses 80% or more of the logic?
  Number of Slice
  Number of Slice LUTS
  Number of Slice LUT-Flip Flop pairs
Thanks for any comments and ideas.
Community Manager
Community Manager
Re: Designs that maximizes (80%)slice and LUT usage, Virtex -5 XCVFX70T
I don't have a design that meets your requirement.
I would advise you to first create the design and then based on the over utilization or timing issues modify the design.
Scholar pratham
Why do you need with 80 per utilization example design?
There are no example designs available
-Pratham
Visitor marahman
Hello Pratham,
One of the requirements from our customer is to fill up the devices logic 80% and then do some testing. So looking at ways how to fill up the FPGA logic .....probably maybe keep instantiating repeatedly until resources are exhausted but that could be tedious to achieve 80% logic coverage.
thanks,
Muhammad
Scholar pratham
Then i think you should design your own
-Pratham
Visitor marahman
True. But any ideas on ways to fillup the logic easily .....any starter design that i can leverage to achieve high logic usuage?
Thanks a lot for you commments.
thanks,
Muhammad
Historian
Historian
thanks,
Muhammad
Big fscking counter?
Check if the attached module helps.
Srinadh
