ERROR:Unsupported XSDB on RIOs
we are using  2 Rocket IOs with virtex7 (XC7VX485t-ffg1930-1)FPGA.
1.We have checked with IBERT IPcore,then we are getting error like
unsupported(XSDB-1),
unsupported(XSDB-16383),
unsupported(XSDB-16384 instead of IBERT console.
2.We have checked with  Aurora protocol  then oberseved that "LANEUP" in "HIGH" state without connecting optical(or SMA) cables.
3.MGT Refclock is coming correctly.
Can you please explain what will be the problem ?
Sunitha
Re: ERROR:Unsupported XSDB on RIOs
Have you generated IBERT from the same version of VIVADO in which FPGA is programmed?
Yes.We have used ISE14.7
Sunitha
http://www.xilinx.com/support/answers/39871.html
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/SDK_Doc/SDK_concepts/sdk_c_xsd_over.html
Thanks and Regards
Balkrishan
