Ethernet Cable is not detected by Vertex 5 Board
Hello Everyone,
i have Xilinx XUPV5-LX110T Evaluation Platform (Vertex 5) board. and Its not detectng the Ethernet cable. What can be the problem?
Re: Ethernet Cable is not detected by Vertex 5 Board
Hello @niteshtripathi,
Have you followed below document
http://www.xilinx.com/products/boards/xupv5/design_files_122/BSB_STD_IP_PCORES/xupv5-lx110t_std_ip_pcores.pdf
Ashish
It is a very generalized statement. What design are you running on this board? Is this a Xilinx reference design and it is not working, then we can help. If this is your custom reference design, then you need to run the simulation and check if the code is good. Then try on HW.
Anirudh
You can rather run the last 2 designs related to ethernet in this link and check if they work - http://www.xilinx.com/univ/xupv5-lx110t-bsb.htm
Anirudh
