Visitor russ.dill
FIFO36E1: RST pin should always have ACTIVE signal for FIFO operation.
I'm getting a DRC error on programming file generation:
ERROR:PhysDesignRules:2022 - Issue with pin connections and/or configuration on
block:<input_fifo/INPUT_FIFO[0].FIFO_DUALCLOCK_MACRO_inst>:<FIFO36E1_FIFO36E1
>. RST pin should always have ACTIVE signal for FIFO operation.
I've tied the RST port of the FIFO to 0, (.RST(1'b0)). Are the tools asking me to manually enable and disable the reset after configuration? Doesn't everything get reset during configuration anyway?
Historian
Historian
Re: FIFO36E1: RST pin should always have ACTIVE signal for FIFO operation.
You don't say which FPGA family you're using, but with Virtex 4 the FIFO had to be explicitly reset after configuration.
Professor
Professor
Some hard IP blocks require an active reset signal after configuration.  It looks like
you're using the built-in FIFO logic, which is probably one of those that needs a reset
signal.
If you don't have an actual reset input to the FPGA (I rarely do) then you can make one
using a short shift register initialized to all 1's, that gets 0 shifted in after configuration.
In Verilog this looks something like:
parameter RES_WIDTH = 4;
reg [RES_WIDTH-1:0] reset_pipe = {RES_WIDTH{1'b1}};
reg reset = 1'b1;
always @ (posedge clk) {reset,reset_pipe} <= {reset_pipe,1'b0};
-- Gabor
Visitor russ.dill
This is with the Virtex-6 LXT.
I've tried the short reset, and it does work, but it produces timing errors. Its an asyncronous FIFO with a slow clock and fast clock.
Timing constraint: PERIOD analysis for net "serial_clk" derived from NET "clk" PERIOD = 10 ns HIGH 50%; multiplied by 7.00 to 70 nS
For more information, see Period Analysis in the Timing Closure User Guide (UG612).
2864 paths analyzed, 2101 endpoints analyzed, 6 failing endpoints
6 timing errors detected. (6 setup errors, 0 hold errors, 0 component switching limit errors)
Minimum period is 71365.000ns.
Paths for end point input_fifo/INPUT_FIFO[2].FIFO_DUALCLOCK_MACRO_inst (RAMB36_X3Y29.RSTRAMARSTRAMLRST), 2 paths
Slack (setup path): -2.037ns (requirement - (data path - clock path skew + uncertainty))
Source: fifo_rst (FF)
Destination: input_fifo/INPUT_FIFO[2].FIFO_DUALCLOCK_MACRO_inst (RAM)
Requirement: 0.002ns
Data Path Delay: 2.056ns (Levels of Logic = 0)(Component delays alone exceeds constraint)
Clock Path Skew: 0.209ns (2.388 - 2.179)
Source Clock: hash_clk_BUFG rising at 4199.998ns
Destination Clock: serial_clk_BUFG rising at 4200.000ns
Clock Uncertainty: 0.192ns
Clock Uncertainty: 0.192ns ((TSJ^2 + DJ^2)^1/2) / 2 + PE
Total System Jitter (TSJ): 0.070ns
Discrete Jitter (DJ): 0.126ns
Phase Error (PE): 0.120ns
Maximum Data Path at Slow Process Corner: fifo_rst to input_fifo/INPUT_FIFO[2].FIFO_DUALCLOCK_MACRO_inst
Location Delay type Delay(ns) Physical Resource
Logical Resource(s)
SLICE_X105Y151.CQ Tcko 0.246 fifo_rst
fifo_rst
RAMB36_X3Y29.RSTRAMARSTRAMLRST net (fanout=7) 1.557 fifo_rst
RAMB36_X3Y29.CLKBWRCLKU Trrec_RST 0.253 input_fifo/INPUT_FIFO[2].FIFO_DUALCLOCK_MACRO_inst
Total 2.056ns (0.499ns logic, 1.557ns route)
(24.3% logic, 75.7% route)
Historian
Historian
Check the data sheet to see if the reset is synchronized internal to the FIFO with one of the clocks. You might need to put a timing ignore on it.
See this in the timing report:
which indicates that the reset signal is in one domain and the FIFO expects it to be in the other. It's only 2 picoseconds, you know!
Visitor russ.dill
I switched to the other clock and the violation followed it, again off my 2ps.
Professor
Professor
This implies that the signal is used in both clock domains, and must therefore be treated
as asynchronous.  You should put a TIG constraint on this to prevent it from using too
much effort during place & route.
-- Gabor
Dear colleague,
Could you please help me in solving this issue!!
Visitor maszoka
Gabor,
I tried this techinque, but the tools did not recognize the reset source as an ACTIVE signal (whatever that might be).
BTW my FIFO is reset by the ~locked of an MMCM, so this sustained PWRON reset should not be necessary in my case.
Xilinx support folks, and guys "doing this for a living" - other ideas on what the tools recognize as an active reset source?
Thanks, Gabor Becker
Scholar dwisehart
Start a new topic.
Historian
Historian
@maszoka wrote:
Gabor,
What I do for things that need such a reset is to use the DCM (or PLL, or whatever) locked signal as a sort of reset trigger, and then hold the reset asserted for some number of clocks after the locked goes true. Locked false holds a short shift register in preset (all 1), and then when the locked goes true, you clock a 0 into the shift register and after a bit the shift register output is a 0.
    signal clk : std_logic;  -- could be DCM output or whatever)
    signal iResetSR : std_logic_vector(15 downto 0) := (others => '1');
    alias gReset : std_logic is iResetSR(15);
MyReset : process (clk, dcmlocked) is
begin
    if dcmlocked = '0' then           -- not locked
        iResetSR <= (others => '1');  -- ensure our reset remains asserted
    elsif rising_edge(clk) then
        iResetSR <= iResetSR(iResetSR'left - 1 downto 0) & '0'; -- clock in 0
    end if;
end process MyReset;
So at initialization time and whenever the DCM is not locked, the reset is asserted.
16 clocks after the DCM locks the reset will be deasserted. And it will be deasserted synchronous with the clock, so it's ideal for use as a synchronous reset in whatever downstream logic you have.
Visitor maszoka
Yidfal,
This was suggested before, and I tried this as well.
Every now-and-then when I bump into this error, I keep debugging until I realize the workaround is not to use the built-in FIFO, just revert back to BRAM based FIFOs. Voila, it works.
I think the bitgen DRC error should be caught and reported in the synthesis stage, and the phrase "active signal" should be elaborated more.
Regards, Gabor
active signal would mean which is not a constant and have some logic associated with it.
If you are going forward to use BRAM based FIFO, mark this thread as answered to close it.
