Visitor nithinks1
FPGA input and output question
Hello ,
    One suggestion I need.
I am using TWO FPGA Boards here.
I am using Virtex 7 FPGA (xc7v2000tflg1925)
Few pins of two FPGA's would be interconnected when I stack them together.
All the Logic will be present in FPGA1.
I want to just route the signals using second FPGA (FPGA2)
The path will be as below
Output signals from FPGA1 ---> input to FPGA2 --> output on FPGA2
Input signals to FPGA1  <-- output from FPGA2 <--- input to FPGA2
Even I want to route clock and reset signals!
Second FPGA, I want to just use for getting signals on one port and send it on other port!
There will no logic in FPGA2!
Can I do this??
Has anybody done this anytime?
Thanks and Regards,
Nithin K S
Re: FPGA input and output question
Hi @nithinks1
Yes, you can forward the signals through the FPGA2.
For clock forwarding use ODDR2.
Vinay
Visitor nithinks1
@vuppala thanks for that!
Yes, I am planning to forward the clock using ODDR2 Buffers.
Can I forward the normal Signals using simple verilog assign statements?
Nithin K S
Yes.
