Help : virtex 5 MIG Design Creation
Hello all,
I'm beginner in FPGA control by verilog.
I wanna use SRAM DDR2 for writing and reading data.
I found ml505_mig_design_creation.pdf
In the guide file, after Generate the MIG(33page), it says I should add overlay files (-ML50x specific UCF file as per
AR29313, - Pre-compiled ChipScope Pro design files used to validate the design)
Also It says "Modify top level Verilog file" (- Support for ML50x Board as per AR29313, - Add ChipScope Pro to design)
I have 2 questions.
1. What's the ChipScope ?
2. I couldn't find about "AR29313". Is anybody who knows about it?
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/chipscope_pro_sw_cores_ug029.pdf
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
