How LUT is configured as Shift register ???
    Can  anyone please explain that How one 6-i/p LUT is configured to 32-bit shif register (SRLC32E) ??
Thanks in advance.
check the following link for the SRL usage from LUT's though this is for 4 input LUT's it can be a good reference for 6 input LUT's
http://www.xilinx.com/support/documentation/application_notes/xapp465.pdf
--Krishna
check langauge template
Thanks and Regards
Balkrishan
 SRL, This design element is a variable length, 1 to 32 clock cycle shift register implemented within a single look-up
table (LUT).Instantiating the device primitve will implement in LUT only.
Library UNISIM;
use UNISIM.vcomponents.all;
-- SRLC32E: 32-bit variable length shift register LUT
-- with clock enable
-- Virtex-6
-- Xilinx HDL Libraries Guide, version 14.7
SRLC32E_inst : SRLC32E
generic map (
INIT => X"00000000")
port map (
Q => Q, -- SRL data output
Q31 => Q31, -- SRL cascade output pin
A => A, -- 5-bit shift depth select input
CE => CE, -- Clock enable input
CLK => CLK, -- Clock input
D => D -- SRL data input
-- End of SRLC32E_inst instantiation
Verilog Instantiation Template
// SRLC32E: 32-bit variable length cascadable shift register LUT
// with clock enable
// Virtex-6
// Xilinx HDL Libraries Guide, version 14.7
SRLC32E #(
.INIT(32'h00000000) // Initial Value of Shift Register
) SRLC32E_inst (
.Q(Q), // SRL data output
.Q31(Q31), // SRL cascade output pin
.A(A), // 5-bit shift depth select input
.CE(CE), // Clock enable input
.CLK(CLK), // Clock input
.D(D) // SRL data input
// End of SRLC32E_inst instantiation
Thanks for your reply But Am not asking language template i am aware of all this .
My query is related to internal working of 6-i/p LUT as shift register.
If any information  related to that please reply.
--Krishna
