How to configure switch boxes in VHDL in Virtex-5 device?
I am wondering if there is a way to cobfigure switch boxes in VHDL, initialize them and connect them consecutively as you wish? I want to connect a series of switch boex together (the output of first is the input of the next), but I do not know is it possible through VHDL or not?
I thank in advance for any kind help and assist.
@gszakacs
Re: How to configure switch boxes in VHDL in Virtex-5 device?
m,
In a word, why?
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank Austin for your reply. I would like to connect a series of switch boxes consecutively in order to verfiy could it act as a delay line chain? That's why I am looking for a way to do that.
m,
The carry chain has typically been used in the past to create a programmable fine grained delay line.
Programming interconnect to do that is hard, and results in unpredictable delay, large variation, and a variation in step size.
I would not recommend it.
Austin Lesea
Principal Engineer
Xilinx San Jose
Dear @dwisehart
I just tumbled again to your post and the hint that you proposed ! Do you know how to configure IODELAY blocks in VHDL and what is the step size of delay in consecutive connected blocks?
Thanks and Regards,
@msdarvishi I do not know how to configure IODELAY blocks in VHDL, but the templates in Vivado should help you out.  If not, post a separate question asking for help.
As for step size, it depends on the REFCLK you use.  The effects of different frequencies are discussed here: http://www.xilinx.com/support/documentation/application_notes/xapp707.pdf
Daniel
