Visitor s021897
How to get light weigth IP (lwIP) running on XUPV2P?
Hi all,
I'm trying to get lwIP running on my XUPV2P board using a Microblaze core and XPS Ethernet lite, and to that end imported the source code for the Spartan3 Echo example, since it also uses a Microblaze core and the XPS lite Ethernet. I've got the DDR running and programming it is no problem (anymore). It now however doesn't want to create a network interface, as can be seen in the Hyperterminal responce:
-----lwIP TCP echo server ------ TCP packets sent to port 6001 will be echoed back Board IP: 192.168.0.10 Netmask : 255.255.255.0 Gateway : 192.168.0.1
MAC address: 00:18:3E:00:10:5F Error adding N/W interface
The error is a responce to:
if (!xemac_add(netif, &ipaddr, &netmask, &gw, mac_ethernet_address, EMAC_BASEADDR)) { xil_printf("Error adding N/W interface\n\r");
Does anyone know what the problem could be, or help me get lwIP running on a Virtex2pro so I can get a small webserver going?
Michael
Visitor s021897
Re: How to get light weigth IP (lwIP) running on XUPV2P?
My post seemed to be premature,
Increasing the stack and heap sizes fixed the problem!
Visitor s021897
Visitor abghassen
I have many problem in using lwip . can you send me your project to have an idea
Visitor s021897
Here's my project including echo and webserver software project
Visitor abghassen
thanks
