Participant boneswu
How to report a dedicated timing path with clock latency information
If I report clock to clock, ISE would worst timing path
There is a too large report to find out the target path.
If I report with OFFSET, report would not show clock latency information.
How to report a dedicated timing path with clock latency information?
Thanks!
Re: How to report a dedicated timing path with clock latency information
You can specify a timing constraint involving specific registers as sources and destinations as well as filter results in the interactive Timing Analyzer tool.  The Timing Analyzer GUI does a great job of allowing you to parse through long reports.  Even if you do command-line batch processing, investigating the Timing Analyzer interactive tool will help significantly.
