I could not put two GTX ip core in the same design
I am going to implentment  two serial link protocol in one design.
I generate two ip core by wizard (ver 1.12)
It always faied when synthesis, the error message is
ERROR:HDLCompiler:687 - "/home/walter/g3/fpga/v6-mgt-trial/ipcore_dir/mgt_sata3/example_design/frame_gen.v" Line 69: Illegal redeclaration of module <FRAME_GEN>.
Is there any way to have different rate serial link in one design by GTX ?
Re: I could not put two GTX ip core in the same design
The case is as if I set gtx 0 at 110 in pcie2 and gtx 1 at 111 in sata2.
Then there is two coregen ip.
Xst failed to synthesis and quit.
Newbie zhuang123
I have the same problem when I try to use different speed configuration for each serdes,
is there any one know how to config the serdes to make sure each serdes be able to run at different speed or different protocol?
thanks
The original post is one year old.  If you need different functions in a module then the module name must also be different.
You have not mentioned the target device.
Each GTX architecture has some requirements to use different protocols inside the same quad/tile.
I recommend to first refer to the GTX user guide for the clocking architecture..
