IDELAYCTRL ref clock
The V5 datasheet specifies the reference clock for IDELAYCTRL as 200MHz.  Is this the minimum frequency?
I only have a 120MHz oscillator, so would I need to create a 200MHz from a PLL or DCM?
Correct 120 mhz is out of spec a pll or sm is required to generate the ref clk
