Visitor trivo5k
IODELAYE1 in Virtex-6
I instantiate an IODELAYE1 for Virtex-6. I use X_IODELAYE1.v and IODELAYE1.v for simulation. Both gave the same result.
IDELAY_TYPE is "VAR_LOADABLE", REFCKF_FREQUENCY is 200.0 (default value)
If I set CNTVALUEIN to be 31 (highest tap) then I get the DATAOUT delay of 2.5 ns (should it be 5 ns instead?). If I set
CNTVALUEIN to be 15, then the DATAOUT delay is 1.3 ns (should it be 2.5 ns instead?)
Are those delay correct? If so, where do these numbers come from?
Re: IODELAYE1 in Virtex-6
Yes, the delays in simulation are correct. The numbers come from the data sheet (see delay resolution in the red rectangle in the snapshot below).
@trivo5k wrote:
Cheers,
Jim
