Interface with ddr3 on virtex 6 ml605
Hi, I have to implement a DDR3 SDRAM SODIMM interfaced with Virtex 6 on ML605 kit. But i'm new to this field. Pls somebody guide me which documents or tutorials i need to refer?
I have read about DDR3 RAM and tried some tests but nothing worked.
Thanks so much.
Tags (2)
Please go through XTP047 and follow the steps
https://secure.xilinx.com/webreg/clickthrough.do?cid=183914&license=RefDesLicense&filename=ml605_MIG_pdf_xtp047_13.4_c.pdf&languageID=1
https://secure.xilinx.com/webreg/clickthrough.do?cid=181926&license=RefDesLicense&filename=ml605_MIG_rdf0011_13.4.zip&languageID=1
Also youcan refer UG406 for MIG details
Hope this helps
-Vanitha
hi,
The newer ML605 boards were shipped with 1G RAM
Refer to AR http://www.xilinx.com/support/answers/44814.html
--hem
Thank you, vsrunga. It's very helpful for me.
Hello.We are also working on ddr3 and facing the same problem as you did, we have made the code but it is not working and giving the results we require. Since you have recently worked on it, could you please help us.
