Interfacing 2 Virtex 5 FPGAs
need help interfacing two virtex-5 FPGAs.which is the best and easiest method?? 32 bit bi-directional or an LVDS design(whatsthis?)
Scholar drjohnsmith
Re: Interfacing 2 Virtex 5 FPGAs
An open question , I'll try to give some sort of reply.
As said above, its highly app dependent.
but,
    try to avoid a bi directional buss,
         two uni directional buss's are much easier to get working.
    A serial link is very easy to get working, use the SERDES in the IO pins.
        you can get a lot of Bit /sec down say a diff LVDS link.
    Assume both Virtex are on same board and close, not meters apart,
        you should have few problems,
    If you have the GTPs available, you can even connect up at a few Gb/sec,
       For slow signlas, you always have SPI ...
just a few examples,
Historian
Historian
This is entirely application dependent.
Scholar drjohnsmith
but,
thank you sir !!
