10-27-2014 10:58 PM
I am making Jtag test with XC5VSX95T_FF1136.
The BYPASS & IDCODE instruction works well. But when I switch to EXTEST mode, there is no data on the TDO.
So I noticed the following lines in ug191 guides:
" If Boundary-Scan is used as part of the product verification in the LXT or SXT, the analog
supply voltage pin MGTAVCC of all GTP_DUAL tiles must be powered. The analog
supply voltage pin MGTAVCC of all unused GTP_DUAL tiles must be connected to the
same supply that supplies VCCINT, which is the power supply pin for the internal core
logic."
These pins on my board goes to GND, so I wonder is this the main reason for EXTEST failure?
10-27-2014 11:50 PM
yes for extest you will need to power the MGTAVCC supply for each GTP_DUAL in the column.
check the following AR
http://www.xilinx.com/support/answers/29766.html
--Krishna
10-27-2014 11:50 PM
--Krishna
