ashkel
ML501 Board RS-232 Serial Communication
I am very new to FPGAs and am trying to implement some very simple RS232 communication between an ML501 board and a PC. What I would like to accomplish is to be able to press a button on the FPGA and register some kind of "Hello World" message in HyperTerminal or a similar program. I am a little stuck on how I should access the RS232 port from the verilog code that I'm writing however. I read the documentation for this board and it does not mention anything about which FPGA pins correspond to RX and TX. Is there some higher level UART module that I can access or is there at least a way to set values for the RX and TX pins?
Thanks!
eteam00
Professor
Professor
Two ways to quickly determine RX and TX pins:
  1. Read the ML501 board schematics (they should be avail online for download)
  2. Open the ML501 FPGA reference design in the ISE design SW suite, and the pinouts should be in the .UCF file.
You don't mention whether you are a board designer, a programmer, student, FPGA design student, etc. etc.   If you have no longterm interest in FPGA design, it seems silly to expect you to learn the design tools and design language to make a simple one-time FPGA design change.
- Bob Elkind
SIGNATURE:
Summary:
mcgett
Normal, I can agree with RTFM type response, but in this case the pin information for the RS232 port is missing from the UG226 the ML501 User Guide, if you look at the schematics you will see that the  following:
AD14 -> UART_SOUT -> T2IN  on the ADM3202ARUZ RS-232 driver
AC7  <- UART_SIN  <- R2OUT on the ADM3202ARUZ RS-232 driver
ashkel
Thank you! This was exactly what I was looking for.
jotz
It is not Clear Enough still so my question is
AD14 must be the pin used to transfer data from the FPGA to the PC and AC7 must be the pin to transfer data from the PC to the FPGA?
eteam00
Professor
Professor
Yes.  The <- and -> arrows in mcgett's post are your helps.
-- Bob Elkind
SIGNATURE:
Summary:
