Observer sidns5
Microblaze , vertex 4 ML403, Accessing register values from C
I am trying to read PC value and print it out in C.
Here the code;
main(){
int x;
-- some huge C code;
asm("mfs r2 0");    -- this loads the value into r2 <- PC.
now how to load the value from r2 into x,   x <- PC.
How do i access register values from C?
Please  HELP, Is their anydocs on this assembly n C,
I did checked out the processor reference guide. no luck:(
Sid
Re: Microblaze , vertex 4 ML403, Accessing register values from C
When assembly is intermixed with C, there are two conventions used for it:
1) Wrap the assembly in a separate C function.
 Here's an example of this:
   unsigned long read_pc(void) {
      asm("mfs r3 0");
 Per the ABI, as documented in the Microblaze UG, r3 is the return value register. Therefore you could invoke this function like so:
    unsigned long pc_val;
    pc_val = read_pc();
 In this case pc_val will hold the value of the PC register.
2) Embed the assembly in another C function and use compiler-specific mnemonics to access C-based storage.
   Here's a link to this from GCC manual . It can be kind of confusing to read, but I recommend it since you should know what you're invoking, before you invoke it.
  Here's an example of that usage:
    unsigned long pc;
    asm("mfs %0 0" : "=r" (pc));
  Theoretically the compiler should use the register storage location for PC and properly fill in the value. If not, you may have to 'register' the variable first:
    register unsigned long pc;
HTH,
- Mike
      asm("mfs r3 0");
    pc_val = read_pc();
    unsigned long pc;
HTH,
- Mike
Observer sidns5
Hi Mike,
That was great info, It really answered my question.
Thanks very much for taking you time , for writing such a nice n detailed reply.
The link to gcc was quite useful.
thanks,
Sid
Observer sidns5
line 43:   register unsigned long pc;
line 121: asm("mfs %0 0" : "=r" (pc));
No errors when I compile the above code but...
When i tried to print..
line 122: xil_printf("PC is:%u.\r\n",pc);
I have this from the compiler
/cygdrive/c/DOCUME~1/siddu/LOCALS~1/Temp/cceypCcN.s: Assembler messages:
/cygdrive/c/DOCUME~1/siddu/LOCALS~1/Temp/cceypCcN.s:121: Error: register expected, but saw '0'
/cygdrive/c/DOCUME~1/siddu/LOCALS~1/Temp/cceypCcN.s:121: Fatal error: invalid value for special purpose register
make: *** [TestApp_Peripheral/executable.elf] Error 1
please HELP,
Sid
