Visitor nikita1584
Nets rxoutclk/txoutclk is not completely routed
I have insert GTH transceiver into my project. When I try to implement the design I have next critical warnings:
6 net(s) are unrouted. The problem net(s) are gt1_rxoutclk_out, gt1_txoutclk_out, gt2_rxoutclk_out, gt2_txoutclk_out, gt3_rxoutclk_out, gt3_txoutclk_out.
2 net(s) are partially routed. The problem net(s) are gt0_rxoutclk_out, gt0_txoutclk_out.
I have tryed to manually routing these nets like in example_ip_project. After routing, I receive 976 overlaps, bad timing and many other unrouted nets.
What should I do?
Re: Nets rxoutclk/txoutclk is not completely routed
Please give more details on how you are using these signals in your design..This could help understand the reason for unroutability by the tool...
Visitor nikita1584
In accordingly with placement
Снимок экрана из 2013-12-19 15:57:53.png
These signals used only for clocking gt0_txpmaresetdone_out, gt0_rxpmaresetdone_out and so on for 1, 2, and 3 transmitters.
May be I should use set_false_path for leds and jtag clock?
I use X1Y36-39 transmitters. I think that some elements (BUFG and PLLE2_ADV) is placed far away from transmitters.
How can I change location of some elements (I mean BUFG and PLLE2_ADV)?
Historian
Historian
Have you instantiated clock buffers on these clock outputs of the GTH? The output clocks of the GTH have dedicated connections to the clocking resources within the FPGA (BUFG, BUFH and maybe even BUFR, I am not sure and I think it depends on the device). The diagram you attached seems to show a direct connection from the GTH to some slices - if this really is the rxoutclk_out nets, then they are probably structurally unroutable without a clock buffer.
Avrum
The diagram does not help the usage. It would help if provide the connections going from these signals to your design.
usually it is like txoutclk/rxoutclk -> bufg (mandatory) -> mmcm (not mandatory) -> GT/user logic.
Can you provide the critical warning message? This could help understand the reason for the warning...
Visitor nikita1584
Thank you for reply! The initial design with gth transmitter was with RXOUTCLK. I connect RXUSRCLK instead of RXOUTCLK in gtwizard_0_init module and design was fully routed.
