Anonymous
Not applicable
PLL on Virtex-5
  Hello, I am trying to realize SFI interface using the code in XAPP856. The system need two clock source (200MHz and 625MHz), but my PCB only has one clock source (125MHz). I want to use PLL to generate the other two clock source.
  The following code shows the method I try to use:
clk_200 clk_200
                 .CLKIN1_IN(CLK_125B),
                 .RST_IN(RESET),
                 .CLKOUT0_OUT(CLK200),
                 .CLKOUT1_OUT(CLK_125)
clk_625  clk_625
               .CLKIN1_IN(CLK_125),
               .CLKOUT0_OUT(CLKOUT_TX),
               .CLKOUT1_OUT(TXCLKDIV_W),
               .RST_IN(RESET)
  Above, clk_200 and clk_625 are the PLL I set. When translate, there are following errors reported:
ERROR:NgdBuild:770 - IBUFG 'clk_625/CLKIN1_IBUFG_INST' and BUFG
   'clk_200/CLKOUT1_BUFG_INST' on net 'CLK_125_W' are lined up in series.
   Buffers of the same direction cannot be placed in series.
ERROR:NgdBuild:924 - input pad net 'CLK_125_W' is driving non-buffer primitives:
Can these problems be solved? How to solve it.
If you are connecting the output of one pll to the second, you will need to remove the IBUFG instantiation in the second PLL module.
Please remove the IBUFG in clk_625 instance of the PLL and connect input net to the IBUFG to output net.
