sergey_s
Problem with running sdrexamples on the board Virtex6 ml605
I have installed ISE 14.7 suit, Matlab 2013b (64bit), and Matlab 2014b (64bit).
My windows system is Win7 64bit.
(Matlab 2013b is running through the system generator)
I open any sdrexamples (with block Analog Devices FMCOMMS)and click Run, then pops up an error:
From block FMCOMMS watch hardware information (RFBoard - Analog Devices AD-FMCOMMS1- RevC)
but when I click Synchronise, I see this error
(When I run these sdrexamples through Matlab 2014b this is no error, but then does not work Systems Generator)
Please tell me how to solve this problem.
Tags (4)
balkris
This is a known issue with the WinPcap installer and can be ignored. This error message does not affect the ability to perform Ethernet Hardware Co-Simulation.
Thanks and Regards
Balkrishan
sergey_s
Yes, Ethernet Hardware Co-Simulation works (MATLAB 2013b).
Does not work model containing block FMCOMMS (which translates our radio broadcast through RFBoard)
Reverse situation in Matlab 2014b: does not work Co-Simulation, but work all model containing block FMCOMMS
