robinson_qtc
Question regarding DCI Cascading (DCI_CASCADE)
I've been reading up on DCI Cascading in the V5 User's Guide (ug190.pdf).  I understand that on the master IO Bank, the VRN and VRP pins should not be used in the user design. What about the slave IO Banks?  Is it possible to cascade VRN/VRP from a neighoring bank and still use the slave bank VRN/VRP pins for user I/O?
ywu
Yes, that's the whole purpose of using DCI_CASCADE.
Cheers,
Jim
Cheers,
Jim
ywu
Cheers,
Jim
Cheers,
Jim
robinson_qtc
Thanks for the clarification!
