Observer bjasionowski
Simulation and Implementation of System Monitor on Virtex 5
I am trying to simulate the system monitor for my Virtex 5 design so I can measure the temperature, Vccaux, and Vccint.
The HDL simulation appears to behave correctly, although I don't understand the values reported since the temperature, vccaux, and vccint all report the same value since do_out only changes once for all 3 values. This can't be correct, but I assume it had something to do with the simulation capability.
I am using the sequencer to step through those outputs and calibration, hence channels 8, 0, 1, and 2 are cycled.
I tried implementing my design and all the values appear to be wrong. The core voltage binary values are 0 and the temperature says something like 120 C after I run the binary word through the calculator. If I monitor the values through chipscope they seem more in line. I removed the heatsink to observe a spike in temperature. I saw the temp rise using chipscope, but the value being reported by the sysmon core was pretty much constant, so I think something isnt' right.
Any thoughts?
