Visitor nithinks1
Synthesis option fast_synthesis resdution in LUT
i am working on Virtex-7 FPGA xc7v2000tflg1925
   I am using synthesis option fast_synthesis
When I set thios otion to "1", after synthesis I get LUT Utilization to 89%
When i set this otion to "0", after synthesis I get LUT utilization reduced to 69%
How is it possible to get so much Reduction??
Nithin
Scholar pratham
Re: Synthesis option fast_synthesis resdution in LUT
@nithinks1 Synplify forum would be correct to answer this question
What i could suggests here is fast_synthsis doesnt do advance optimization which normal synthsis does inorder to reduce the run time hence resulting larger utilization.
-Pratham
To my knowledge this option optimizes the design for better synthesis run time at the cost of area/utilization numbers.
Its design choice to have a trade-off between area & performance.
As suggested by pratham, contact synopsys for more details.
Thanks,Vijay
@nithinks1
When you select run time as priority for a particular run then tool will not try much to enhance the performance as compare to other runs when performance is set as priority. As per my understanding, tool will try to deliver the best results with reduced overall run time.
Anusheel
Helpful answer -> Give Kudos
