UCF file modification of ML605 Ethernet MAC tri-mode core
Hello:
My FPGA board is virtex-6 ML605, and I use ISE 14.5 to generate the embedded MAC wrapper.
And I chose SGMII tranceiver.
The original .ucf file of the physical interface constain was modified as:
NET "MGTCLK_N" LOC = "H5"; #
NET "MGTCLK_P" LOC = "H6"; #
NET "TXP" LOC = "A3";
NET "TXN" LOC = "A4";
NET "RXP" LOC = "B5";
NET "RXN" LOC = "B6";
INST "*gtx0_v6_gtxwizard_i?gtxe1_i" LOC = "GTXE1_X0Y19"; #TNM = "fifo_read"; #"GTXE1_X0Y8";
to fit the SGMII interface.
But, I have a question.
The top module of the example design named as "v6_emac_v1_6_example_design"  has more input/output port than that described in the .ucf file.
For example, the "RESET" port in the top module is not assgined to any location in the .ucf file.
There are a lot of ports that seem to be unconnected.
Should I mannully add additional pin locations in the .ucf file?
Thank you,
Chen-Yang Lin
you can manually modify the ucf file by referring master ucf of ML605 board.
Thanks and Regards
Balkrishan
Thanks and Regards
Balkrishan
The latest version of the core will give you the full UCF.
Attached the UCF from the latest core which you can use.
Satish
hello,
Thank you for your advice.
In my situation, the top file (.vhd) has much more I/O port than the default .ucf.
The default ucf only defines ports such as,
----------------the UCF--------------------------
CONFIG PART = xc6vlx240tff1156-1;
Net mgtclk_n LOC = H5;
Net mgtclk_p LOC = H6;
Net txp LOC = A3;
Net txn LOC = A4;
Net rxp LOC = B5;
Net rxn LOC = B6;
---------the entity of top module------------------------
entity v6_emac_v2_6_example_design is
port(
-- Client receiver interface
EMACCLIENTRXDVLD : out std_logic;
EMACCLIENTRXFRAMEDROP : out std_logic;
EMACCLIENTRXSTATS : out std_logic_vector(6 downto 0);
EMACCLIENTRXSTATSVLD : out std_logic;
EMACCLIENTRXSTATSBYTEVLD : out std_logic;
-- Client transmitter interface
CLIENTEMACTXIFGDELAY : in std_logic_vector(7 downto 0);
EMACCLIENTTXSTATS : out std_logic;
EMACCLIENTTXSTATSVLD : out std_logic;
EMACCLIENTTXSTATSBYTEVLD : out std_logic;
-- MAC control interface
CLIENTEMACPAUSEREQ : in std_logic;
CLIENTEMACPAUSEVAL : in std_logic_vector(15 downto 0);
--EMAC-transceiver link status
EMACCLIENTSYNCACQSTATUS : out std_logic;
EMACANINTERRUPT : out std_logic;
-- SGMII interface
TXP : out std_logic;
TXN : out std_logic;
RXP : in std_logic;
RXN : in std_logic;
PHYAD : in std_logic_vector(4 downto 0);
-- SGMII-transceiver reference clock buffer input
MGTCLK_P : in std_logic;
MGTCLK_N : in std_logic;
-- Asynchronous reset
RESET : in std_logic
But other I/O ports in the top file seems to be missing in the ucf file.
Do I need to add all I/O to the .ucf mannually ?
Thank you
Chen-Yang Lin
