Visitor vlsi_sata
Unable to modify SIM_TX_ELEC_IDLE_LEVELvalue to z
I am using Virtex 6 GTX for SATA FPGA simulations.
During simulations in OOB phase, when TXELECIDLE is 1, Line has to be 'z' inbetween bursts.
But I see an 'X' instead. Which is wrong.
When I tried to modify this using SIM_TX_ELEC_IDLE_LEVEL parameter of GTXE1, I am getting error from that:
ERROR: Invalid SIM_TX_ELEC_IDLE_LEVEL value z
(Tried with caps Z too.. same issue)
Could you pls help me out of this 'x' and make line z.
Many Thanks
Scholar pratham
Re: Unable to modify SIM_TX_ELEC_IDLE_LEVELvalue to z
@vlsi_sata It should work, What tool version are you using and which simulator? Is this error seen on ISIM?
-Pratham
Scholar pratham
-Pratham
Visitor vlsi_sata
Hi Pratham,
Ya, It worked. Actually small z is not working. Only Caps Z is working.
I realized it today.
Thanks for your prompt reply.
Scholar pratham
@vlsi_sata Great! please close this thread.
-Pratham
