V5 FPGA configuration from platformflash XCF16P
Hi, I am planning to use XCF16P for configuring my XC5VLX30T FPGA. I have 2 requirements: 1. During initial stage of project PROM should be programmable from JTAG to change the design. 2. Later on the same board will be used with a preloaded (once programmed) PROM with the final revision of the design. This board will undergo power recycling and no JTAG interface will be connected(i.e NO PC). I plan to use Master select MAP .I have designed the circuit as given in the userguide of PROM for selectMAP mode. The done pin is pulled up and buffered(74LS00) and then used for generating reset for user logic. we will have 2.5V supplying the PROM's VCCint and VCCJ and VCCO_0 of FPGA. The 2.5 V supply will also be connected to VCCJ pin of Cable4. TMS and TCK are connected to both FPGA and PROM. TDI of connector goes to TDI of PROM then TDO of PROm goes to TDI of FPGA TDO of FPGA goes to TDO of connector. other connections are as per the userguide. regards
     No replies yet. Please help.
Instructor
Instructor
What information do you need that is not found in UG191?  Please be specific whenever possible.
Have you read the New Users Forum README thread?  There are some useful links, information, and duggestions.
-- Bob Elkind
SIGNATURE:
Summary:
     1.What i want to know is for the above two requirements whether the circuit is sufficient or do we need some additional circuit.
     2.We did not find the values for the parameters given in fig 1-4 Device powerup timing.
     3.Can you please explain the sequence of operation with respect to the connections shown in MasterselectMap configuration.
regards
Instructor
Instructor
Your circuit description is incomplete.  Suggest you post a board schematic which describes the configuration (including JTAG) logic on your board.
You will find the specifications in the Virtex-5 datasheet (DS202).  See Table 70.
3. Can you please explain the sequence of operation with respect to the connections shown in MasterselectMap configuration.
I do not understand your request.  Can you be more specific?
Have you read the SelectMap section in Chapter 2 of UG191, including Figures 2-14 through 2-18?
-- Bob Elkind
SIGNATURE:
Summary:
