V6 IDELAYCTRL_REF
The recent update to the V6 DC and Switching Characteristics (DS152 v2.3) includes a change to the Fidelayctrl_ref spec for the -2 parts (Table 52).  It changes from 200MHz to 300MHz.  Do I have to use 300MHz or can I use either 200 or 300MHz for the -2 and -3 parts?  The IO User Guide (UG361 v1.1) says in table 2-6 that the REFCLK_FREQUENCY attribute for the IODELAYE1 is "190 to 210 in all speed grades or 290 to 310 in the -3 speed grade"
I just want to be clear if both 200 and 300 MHz are usable for the faster speed grades, not just 300MHz.
Thanks!
Re: V6 IDELAYCTRL_REF
The datasheet isn't very clear on this, but yes.  200MHz and 300MHz are both allowed for the -2 and -3 speedgrades.
Good to know.  Thanks!
