Historian
Historian
Virtex-4 INIT_B and Slave Serial configuration oddness
I have a system design in which a Virtex-4 LX is configured in slave serial mode from a microcontroller. The previous batch of systems built up a couple of years ago work flawlessly. A new run has a few boards which fell out due to some odd behavior.
At system boot time or as a result of a software command, the micro will configure the FPGA. The micro pulls down on PROGRAM_B, then clears DIN and CCLK, and finally pulls down on INIT_B. The INIT_B pin on the micro is configured as open-drain and a 4k75 pull-up resistor is installed on the line. After a setting up a few things, the micro releases first PROGRAM_B and then INIT_B.
But ... INIT_B doesn't go high when I release it. It goes high much later (order of several milliseconds). This is quite bizarre.
The data sheets give no mention of the timing of INIT_B with respect to PROGRAM_B, nor is there a minimum pulse width given for it. (The width of PROGRAM_B far exceeds the datasheet minimum of 300 ns.)
I suppose that a workaround would be for the micro to release INIT_B and then turn around and wait for it to actually go high before continuing the configuration. But it's odd that this same code which worked on a couple dozen boards now fails on a couple of the new builds.
I've verified that the power supplies are good, and this process happens well after the supplies are stable.
Any ideas about this behavior?
Hi Bassman,
If you see the Virtex-4 configuraiton guide the Init_b signal will be low approx prog_b pulse width + Tpl(program latency).
Kindly check the figure 1-3 in the UG071
http://www.xilinx.com/support/documentation/user_guides/ug071.pdf
Tpl should be calculated based on the bitstream size of the device you have.
In the datasheet the Tpl is available and it is 0.5 Us/frame.
http://www.xilinx.com/support/documentation/data_sheets/ds302.pdf
If you consider XC4VLX200 as an example, the Tpl should be around (37,500*0.5 ) 18.75ms
Hope this info helps.
How much time is the init_b is low after the prog_b is high in your case?
--Krishna
Historian
Historian
@kkn wrote:
Hi Bassman,
OK, for my PROGRAM_B pulse width of 500 ns, I measure INIT_B low for ~229 us. INIT_B is asserted barely 167 ns after the assertion of PROGRAM_B.
The obvious question, then, is: once my master asserts INIT_B, does the FPGA ensure that it remains low for Tprog_b + Tpl, or must I ensure that I keep it asserted for that time?
Remember that I am not relying on the FPGA's power-on logic to start configuration, I am doing it whenever the application requires the FPGA to reconfigure.
I'm using XC4VLX15,  with 3,740 device frames, so Tpl is 1.875 ms.
The data sheet gives Tpl as 0.5 us/frame max, which implies  that it could be much faster, which must be the case if I see it go away after 229 us.
The solution is what I proposed earlier: assert INIT_B and then stop driving it shortly thereafter, and then spin on INIT_B, waiting for it to go high before continuing with configuration. I've been testing this and it seems reliable.
