Visitor xvister
Virtex 4 configuration memory architecture
hi,  i'm confused where i can find the configuration memory architure for Virtex-4, or the number of "columns per device/ frames per column" for “CLB/ IOB/ IOI/BRAM...”
Re: Virtex 4 configuration memory architecture
Hello @xvister,
Below documents can be helpful
http://www.xilinx.com/support/documentation/user_guides/ug070.pdf
http://www.xilinx.com/support/documentation/data_sheets/ds112.pdf
Ashish
Hello @xvister
Check chapter 7 in the following user guide: http://www.xilinx.com/support/documentation/user_guides/ug071.pdf
Vinay
