berger_tal
Virtex 5 Configuration Modes
I want to configure the virtex 5 in the fastest way . Which mode I should use to get it?
Tal
evgenis1
Advisor
Advisor
32-bit Parallel Slave SelectMAP configuration mode should be the fastest.
OutputLogic
pradeep_inda
Can anybody tell me more about SelectMap.
some links or Appnotes will also do..
THanks
Pradeep
evgenis1
Advisor
Advisor
Hi Pradeep,
Here is the link to Xilinx User Guide 191 that describes Virtex5 configuration, including SelectMap: http://www.xilinx.com/support/documentation/user_guides/ug191.pdf
Hope that helps,
OutputLogic
