dbarrowman
Virtex 5 GTP Rocket IO Multiple Clock selection
I need to select between two different external reference clocks for the GTP Rocket IO tile, 156.25MHz and 125MHz. What would be the best/cleanest way to do this? Both reference clocks would be coming from external differential oscillators (thus very low jitter) and I would select which would feed the Rocket IO reference tile. Can I just use the simple global clock mux selector or do I need to do something more fancy, such as two DCMs and a PLL (to clean up jitter)?
Dan
gszakacs
Instructor
Instructor
I have done this exact thing, but I used an external 2:1 LVDS multiplexer to allow
use of the GTP direct reference clock input.  I would not suggest using fabric
clocks as a GTP reference.
-- Gabor
borisq
consider ICS85401, which is a clock mux that is used for GTPs' ref clocks on ML50x demo board.
chichu
"consider ICS85401, which is a clock mux that is used for GTPs' ref clocks on ML50x demo board."
Are they die ports J20 and J21 for ML505?
ist it right?
################ Init Clock Constraint #########################
NET INIT_CLK        LOC=AH15;   #100 Mhz Oscillator
################ GTP CLOCK Locations of the pins##############
NET GREF_CLK_P  LOC=j20;
NET GREF_CLK_N  LOC=j21;
Message Edited by chichu on 02-25-2009 08:01 AM
dbarrowman
Thanks for the suggestions.
A related question.....I also need to switch between a 20/16 bit and 10/8 bit interface on the Rocket I/O. Can I do this using the DRP configuration port? Otherwise I have to add some staging logic to take a 16 bit 1x clock rate interface and change it to an 8 bit 2x clock rate interface. I'd rather not do that.
Dan
vila
oh,this tips is too old now.
_____________________
louis vuitton handbags
