yusufs
Virtex VI (ML605) supports Vivado?
Hello all,
           Whether Xilinx Virtex VI (ML605) Evaluation Board supports Vivado ?. What is differents between ISE and Vivado.  can we write VHDL code from Vivado.
YUSUF SIDDIK
ashishd
Vivado Design Suite is Xilinx's new generation tool. Vivado supports 7 series and later devices. You can check page #10 from below UG to check supported architectures with Vivado
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug973-vivado-release-notes-install-license.pdf
Ashish
anusheel
No, Vivado does not support older devices.
Check below links for more details on Vivado IDE:
http://www.xilinx.com/products/design-tools/vivado.html
https://www.youtube.com/watch?v=H6W4HKbjnaQ
Yes, you can write/source your RTL code in Vivado.
Anusheel
Helpful answer -> Give Kudos
