WARNING:Route:466 - Unusually high hold time violation
Hi all,
I have a warning here that I can't fix. When this warning shows up, PAR takes extra time to try to work around it, making my implementation very time-consuming.
I believe this is all related to the chipscope blocks I put in and the block RAMs they're consuming. Anyway, here is the warning message:
WARNING:Route:466 - Unusually high hold time violation detected among 60 connections. The top 20 such instances are
   printed below. The router will continue and try to fix it
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_12:Q2 -> i_ila_1/i_dt1/1/data_and_trig_dly1_47:AX -2688
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_03:Q2 -> i_ila_1/i_dt1/1/data_and_trig_dly1_35:DX -2682
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_11:Q2 -> i_ila_1/i_dt1/1/data_and_trig_dly1_43:DX -2674
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_12:Q4 -> i_ila_1/i_dt1/1/data_and_trig_dly1_15:AX -2674
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_07:Q2 -> i_ila_1/i_dt1/1/data_and_trig_dly1_39:DX -2665
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_13:Q4 -> i_ila_1/i_dt1/1/data_and_trig_dly1_15:BX -2653
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_08:Q1 -> i_ila_1/i_dt1/1/data_and_trig_dly1_59:AX -2649
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_11:Q3 -> i_ila_1/i_dt1/1/data_and_trig_dly1_27:DX -2649
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_07:Q3 -> i_ila_1/i_dt1/1/data_and_trig_dly1_23:DX -2649
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_11:Q4 -> i_ila_1/i_dt1/1/data_and_trig_dly1_11:DX -2648
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_11:Q1 -> i_ila_1/i_dt1/1/data_and_trig_dly1_59:DX -2644
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_13:Q2 -> i_ila_1/i_dt1/1/data_and_trig_dly1_47:BX -2637
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_03:Q3 -> i_ila_1/i_dt1/1/data_and_trig_dly1_19:DX -2626
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_00:Q4 -> i_ila_1/i_dt1/1/data_and_trig_dly1_3:AX -2619
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_08:Q3 -> i_ila_1/i_dt1/1/data_and_trig_dly1_27:AX -2613
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_04:Q1 -> i_ila_1/i_dt1/1/data_and_trig_dly1_55:AX -2612
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_04:Q4 -> i_ila_1/i_dt1/1/data_and_trig_dly1_7:AX -2607
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_09:Q4 -> i_ila_1/i_dt1/1/data_and_trig_dly1_11:BX -2607
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_07:Q1 -> i_ila_1/i_dt1/1/data_and_trig_dly1_55:DX -2590
SDR_4TO1_16CHAN_RX_0/ISERDES_RX_DATA_04:Q2 -> i_ila_1/i_dt1/1/data_and_trig_dly1_39:AX -2538
This warning occurs if I route a global clock to the ILA block. If I route a local clock, the design will fail and complain that the design could not be fit and then it would also mention the related blocks shown above.
What can I do to fix this?
Thank you.
Re: WARNING:Route:466 - Unusually high hold time violation
hi i m getting same problem. can u tell me how to fix this problem.
thank u
And it isn't clear if you have this same problem or not.
First, clocks should only be connected the ILA clock port.  Connecting them TRIGGER or DATA ports will not result in any meaningfull data as the ILA logic samples these ports with the clock connected to the clock port and will result in a static value.
Second, these warning messages appear to be from an IOB ISERDES to the DATA port of the ILA block and the likely cause is different clocks were used on the ISERDES CLKDV and the ILA clock port.
Third, when posting please include the software version and fpga device that you are using as there are numerous differences between versions and FPGA families.
