XC4VFX60-11FFG1152C
HI,I want to get the information of XC4VFX60-11FFG1152C about,
1) a maximum number of single-ended digital input/out
2) an aggregate one-way peak serial transceiver data rate
many thanks!!
Here is the product overview of the V-4 devices - http://www.xilinx.com/support/documentation/data_sheets/ds112.pdf
1) CHeck PG 2, Table 1 which has the information on the maximum number of IO's and also about other logic cells, GT's etc. For this device FX60, the maximum user IO's are 576 out of which you can use them either as single ended or as differential. More information about exact package pin
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
2) The maximum data rate using the trasceivers is 6.5 Gbps. This info can be found from the datasheet - http://www.xilinx.com/support/documentation/data_sheets/ds302.pdf Pg 16
Anirudh
