Anonymous
Not applicable
could TXUSRCLK(RXUSRCLK) of GTP come from CLB, not BUFG?
since there are 32 BUFGMUX in V5. It is a little small for my application.
The USRCLKs will also be used for data paths which will have a lot of loads these need to be on global clocks.
Anonymous
Not applicable
Thanks for your reply.
Something confuses me now. When i use GTX(V5) with TX/RX buffer mode, is it necessary to emply (TXOUTCLK + BUFR) to drive TXUSRCLK, RXUSRCLK,  TXUSRCLK2 and RXUSRCLK2? GTX would not work normally, even when TXOUTCLK + BUFG  drive the above 4 signals. And It would not work that  TXOUTCLK + BUFR drives TXUSRCLK and TXUSRCLK2,  RXCRCCLK + BUFR drives RXUSRCLK and RXUSRCLK2,
I read your post a few times, but I can't understand what your question is. I would suggest that you try using the GTX wizard ad a tarting point for your design.
