delay line design in virtex4
Dear friends,
                        I am trying to design a delay line in XC4VLX200 FPGA. I knwo that it has IDELAY but no ODELAY. Can any one suggest how to design a delay line in FPGA.
Any help is appreciated.
thanks
Re: delay line design in virtex4
any inputs plz.
Historian
Historian
@waris.mohammad wrote:
Dear friends,
thanks
How about providing more details?
What is the maximum delay time? What is the delay granularity (minimum delay time)? Are you delaying single bits or multi-bit words?
I have 40MHz clock signal that i want  to  delay  in steps of 400 ps.i need 64 taps.
and i want to generate many outputs with different phases .
Historian
Historian
In an FPGA? Pretty much impossible.
Teacher muzaffer
As you are not likely to get this in a Xilinx FGPA, if you tell us why you think you need this maybe we can tell you another way to solve your problem.
Also let me guess, at some point, you will want to select of these 64 clocks to register some flops?
so how much is achievable in v4 fpga?
i want to generate clocks for ccds.design need to support 3 different types of ccds.so i thought i will use delay lines.
check using the DCM_TAP functionality available. Refer to Virtex-4 FPGA user guide for more details.
http://www.xilinx.com/support/documentation/user_guides/ug070.pdf
Specification about TAP delay can be found in the data sheet Table 50
http://www.xilinx.com/support/documentation/data_sheets/ds302.pdf
Historian
Historian
What CCD needs clocks with that sort of timing resolution?
design  need to support more than 1 ccd.
one examples are ft18 from dalsa.the reset gate pulse is critical.
dear venkata,
i need to generate many clock .
Teacher muzaffer
I think your design approach may need revision. Take a look at this app note which is doing the FT18 interface. Are you trying to accomplish the same goal?
http://pdf.datasheetarchive.com/indexerfiles/Datasheet-038/DSA0061336.pdf
Historian
Historian
Generally, the design is done to support a specific CCD. If you need to support a different sensor, you modify the design as necessary. It's a fool's errand to think that you could possibly support multiple devices in the manner you're considering.
It's not like you're going to just swap out sensors in the camera without changing other aspects of their operation, such as clock voltage levels and biases and such.
You may want to consider using an application-specifc IC for this task.  For example, the AD9970 (and relatives) allow you to run a CCD at 40 MHz and choose the horizontal clock rising and falling edges from 64 PLL taps, exactly as you describe.
-Greg
Teacher muzaffer
It seems you don't need to generate many clocks but the ability to shift your edge precisely. I think you can use an IDELAY element to do the latter.
We need Odelay for the same. Which is not available in V4 FPGA.
