stalha
error iMPACT 583-'1': idcode mismatch between bsdl file and read from device
While configuring my virtex-4 (sx35) using Platform cable USB (with XilinxISE7.1i), I get following message off and on.
error iMPACT 583-'1': The idcode read from the device does not match the idcode in the bsdl file
By off and on I mean that one-day this problem comes (and goes after wiggling of some wires and/or re-booting of computer and/or turning off & on the PC monitor), then for many days there's no problem (device configuring perfectly well) and then suddenly, this problem comes back again. Today is that day and since morning, I'm busy with it but the problem is still there. I 've also downloaded latest bsdl files for xc4vsx35 into the folder xilinx/virtex4/data and xilinx/xpla3/data, but of no use. Could anyone help please ?
mcgett
What this indicates is that the JTAG chain on the board has some signal integrity issues most likely on the TCK (clock) line.  This is causing incorrect data to be read out of the board occasionally.
JTAG may be a slow interface, but it is just as susceptible to clock glitches as any other interface.
stalha
Thanks for the reply.
This problem that I'm getting is with our project-circuit1 which is housing xc4vsx35. However when I use the same setup (same ISE, Platform cable USB) to configure the 'Xilinx® Virtex™-4 SX Evaluation Kit (which is housing xc4vsx35)', there has never been any problem at all. Similarly, when I use the same setup (same ISE, Platform cable USB) to configure our another project-circuit2 housing Xilinx CPLD, there too has never been any problem at all. So, does it show that there's problem in our project-circuit1 (the one housing xc4vsx35) ?
"What this indicates is that the JTAG chain on the board has some signal integrity issues most likely on the TCK (clock) line.  This is causing incorrect data to be read out of the board occasionally."
Could it be related to the PCB-quality of the project-circuit1 ?
mcgett
Since the same software and cable works on 2 out of 3 different boards then the problem is on the board that doesn't work.
The board that you are calling the "project-circuit1" board has a problem with the way that it was designed.  I would suggest that you get out an oscilloscope and probe the TCK lines at each device on the board to see if you can determine where the problem(s) is.  Depending on what you find you may be able to fix the signal integrity problem with the capacitor or a resistor.
iffy2002
I'm having a similar problem, but looking at the device  idcodes ... I can see that they're just shifted by 2 bits.  How would I fix this?
Cable connection established.
Firmware version = 1301.
File version of /home/matt/Xilinx92i/data/xusb_xlp.hex = 1301.
Firmware hex file version = 1301.
ESN Family Code: 00
ESN: 000000000000
CPLD file version = 0012h.
CPLD version = 0012h.
ERROR:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000111000010001000001001001100
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000001110000100010000010010011
akleica
How many devices are on your board? 3 perhaps?
borisq
use iMPACT to identify the jtag chain "automatically", don't choose "manually"
ddaadd
^.^....  i'v solved..
iMPACT 10.1.03
usb download cable...
my board list..
#20 set
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000010101101100000100000010011
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000110110110001000000010010011
#13
INFO:iMPACT:1578 - '1':  Device IDCODE :        00001111111111111000111111110011
#4
#3
 It took three days to resolve
TMS : 1K PULL DOWN
TDI, TDO, TCK : 1K PULL DOWN...
altera application...
hfsitu
My solution for this is just slow down the cable speed to 200KHz, act as Parallel III. It works for me.
delbotero
I am using a SPARTAN 3 starter kit.
I developped my first project with BSB, but I have one error, according with this thread is due to the board. How to solve it?
INFO:iMPACT:501 - '1': Added Device xc3s200 successfully.
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode
   in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000000000000000000000000010001
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000001010000010100000010010011
make: *** [download] Error 1
Done!
Thank you in advance.
DABG
ddaadd
TDI, TDO, TCK : 1K PULL DOWN...   --->  Pull Up
and change download speed
kresimir
Hello, I have the same problem with this idcode. I use Jtag cable (coolrunner II). a) I reduced TCK (750 kHz) b) 1 K pull down for TDO, TCK, TDI I didn't helped.
Krešimir Popović
kresimir
I will try this schematic for programming. It will be used for CoolRunner II CPLD XC2C32A (VQ44).
Krešimir Popović
kresimir
This should be even better. I have included C = 0.1 microF.
Krešimir Popović
suchit_ee
For anyone who runs into the IDCODE mismatch issue the first time they are programming their kit:
Before you do anything fancy, take a few minutes to read-up on the jumper settings necessary for successfully programming your kit. In my case I am configuring an ML605 which arrived yesterday. After I got the IDCODE mismatch, I checked the hardware user guide, and found out the correct jumper settings. Now my bitstreams are downloading.
Cheers!!
bassman59
Historian
Historian
Cheers!!
Ah, you Read The Fine Manual?
You must be new here :)
hongtay
I used ISE 14.3 nt64bit
  with device : XC3S500E-PQG208
  USB JTAG : ALTERA XILINX Lattice Saleae USBee 5 in 1 USB blaster Download Cable JTAG FPGA CPLD Downloader Debugger
  from  http://www.canton-electronics.com/
   got  below error
    info:impact:1578 - '1':  device idcode :        00000011100001000100000100100110
    info:impact:1579 - '1': expected idcode:    00000001110000100010000010010011
  I soft by used Impact  just  click-> Boundary Scan --> right click on bank right side windows  --> Initialize chain CTRL + I
  you will found 2 device one device is first chain that you programing  and other one is XC??? is inside USB JTAG loader
 then you load program only first you device don't touch other one  then try  Get device ID will working normal
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000011100001000100000100100110
GUI --- Auto connect to cable...
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.3
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Driver file xusbdfwu.sys found.
 Driver version: src=1027, dest=1027.
 Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
 Cable PID = 0008.
 Max current requested during enumeration is 280 mA.
Type = 0x0605.
 Cable Type = 3, Revision = 0.
 Setting cable speed to 6 MHz.
Firmware version = 1100.
File version of D:/Xilinx-web/14.3/ISE_DS/ISE/data/xusbdfwu.hex = 1100.
Firmware hex file version = 1100.
PROGRESS_END - End Operation.
Elapsed time =      1 sec.
Type = 0x0605.
ESN not available for this cable.
Enumerating cables. Please wait.
Found cable - > ESN not available for this cable.
No ESN.
Connecting to cable (Usb Port - USB22).
Elapsed time =      3 sec.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 1/16/2013 4:00:43 PM
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xcf04s, Version : 13
INFO:iMPACT:1777 -
Reading D:/Xilinx-web/14.3/ISE_DS/ISE/xcf/data/xcf04s.bsd...
INFO:iMPACT:501 - '1': Added Device xcf04s successfully.
'1': : Manufacturer's ID = Xilinx xc3s500e, Version : 4
INFO:iMPACT:501 - '1': Added Device xc3s500e successfully.
done.
'1': Loading file 'X:/M-Power/MOTOR-500E/2013-01-16/main.bit' ...
done.
UserID read from the bitstream file = 0xFFFFFFFF.
INFO:iMPACT - Current time: 1/16/2013 4:01:25 PM
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': IDCODE is '01000001110000100010000010010011'
'1': IDCODE is '41c22093' (in hex).
INFO:iMPACT - Current time: 1/16/2013 4:01:30 PM
Validating chain...
INFO:iMPACT - Current time: 1/16/2013 4:01:31 PM
Anan P.
Thailand
