internally reset FPGA
Is there any way to internally assert PROGRAM_B or the equivalent? I'd like to programmatically reconfigure a Virtex5, i.e. to initiate a configuration process on-the-fly from my user logic. I do not have any means to reset/reprogram the FPGA from an external processor, other than JTAG. The board has an SPI configuration interface; if I can reset the FPGA it will configure from the SPI flash, without me having to send a JPROGRAM (or whatever it is) command over JTAG.
Please note I'm not asking about partial reconfiguration - I just want a full reconfiguration. And I'm not asking about a global reset (GSR) to the previously-programmed configuration.
Historian
Historian
You need a spare output pin that you can wrap around and connect, external to the FPGA, to PROGRAM_B. That output should be open-drain. Drive it low, it yanks down on PROGRAM_B, and once configuration starts, the logic that drives it goes away and the pin itself is tristated or pulled up (depending on the state of the HSWAPEN pin).
Historian
Historian
