outputting signal bits to virtex 5 pins
I am using virtex-5 FX30T fpga, i wrote, and simulated a code that generates triangular and sawtooth signals (8 output bits), and i need to output these bits to appropriate pins to connect them to a DAC (digital to analog converter). I looked at all relevant datasheets. This (http://www.files.em.avnet.com/files/177/xlx_v5fxt_evl-ug-rev1.pdf) is the datasheet for the fpga, the xilinx user guide for fpga's (http://www-inst.eecs.berkeley.edu/~cs150/sp13/resources/ug190.pdf) makes it seem that i should use OBUF outputs (chapter 6), and the virtex 5 gpfa packaging and pinout (http://www.xilinx.com/support/documentation/user_guides/ug195.pdf) doesn't seem to offer any clear indications as to what pins are OBUF(my device is the one corresponding to the table starting at page 40 (FF665)).
How can i know to what pins should i map my outputs in the ucf constraints file in order to able to output the bits of my signal and then use them to drive a digital-to-analog cicuit (such as a R-2R ladder)?
Thank You
