martel
partial reconfiguration with compact Flash, Microblaze and ICAP
Hi everybody,
I think I have an interesting question. I've achieved partial reconfiguration with compact Flash, ICAP and Microblaze. My partial bit file are stored in the compact flash. And I've seen that the function that load partial bit file from compact Flash to ICAP( xilinx function) is not very efficient for timing because it store a part of the partial bit file in the RAM of the Microblaze.
And then, send it to ICAP. This function do this until the end of the partial bit file.
I would like to know if it exist a function ( xilinx function or home made function) wich enable me to do a direct transfert between compact Flash and ICAP. It means a function wich operate like a DMA transfert in order to upgrade my reconfiguration timings.
The Microblaze know for example the beginning, the ending and the size of the partial bit file to be loaded. Then it transmit this information to ICAP and the transfert is done quickly.
Thanks for any answers.
martel
Does anyone have an idea ?
eteam00
Instructor
Instructor
Not me, sorry.  Official, primary Xilinx first-line support access is through webcase or tech-support hotline.  The user forums are not considered the primary venue for soliciting Xilinx tech support.
-- Bob Elkind
SIGNATURE:
Summary:
fanakin
Hi, I did the same with ML507 board. It has PPC440 hardwired into the virtex5 FTX FPGA. The problem I think is the bottleneck betwwen SoC RAM and CF. You can verify that aspect.
harshavs
Hello Martel.
You can use directly ICAP for configuring the FPGA.
Refer UG360 document, to the topic IPROG using ICAP.
This gives solution to your question.
Harsha
ali.akber14
Hello martel, can you provide me your email id i am also working on partial reconfiguration but have problem with the interface between compact flash and ICAP. I will be grateful to you, if you can provide me your email ID so that i can contact you directly.
