programming virtex 7
hi
does xilinx 12.1 support Virtex 7
regards
uzmeed
Re: programming virtex 7
No its not supported you need to use ISE 14.7 to work with virtex-7 devices
You can use latest version of ISE which 14.7 or vivado tool
You can find ISE versions here
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools.html
Vivado tool you can download from here
http://www.xilinx.com/support/download.html
The old tools you can download from here
http://www.xilinx.com/webpack/classics/wpclassic/
Thanks and Regards
Balkrishan
I m sory i wanted to as about kintex 7
regards
kintex-7 also is not supported in 12.1 ise, you need to use 14.7 ise or vivado latest version
