"SysAceSelfTestExample FAILED" for ML510 -- Compact Flash
UPDATE: The SysAceSelfTestExample test fails when:
1)  It checks to see if interrupts are disabled
2)  It checks to see if interrupts are enabled
I am getting the “SysAceSelfTestExample FAILED” during the SysAce configuration peripheral test.  Not sure what is wrong so any help would be appreciated.
Here are the details:
1)  Using EDK 11.3
2)  Board: Virtex-5 ML510 FPGA (XC5VFX130T)
3)  CF card is properly formated as FAT16
4)  SysAce configuration via the provided CF card works, so the CF card is being read
When I build my own system using the Base System Builder, the SysAceSelfTestExample fails for the TestApp peripheral test as well.  Those details are:
1)  Using standalone system, with xilfatfs and write capability selected
2)  Previously used C code worked on both Virtex II and ML507 boards
3)  Tried using 10.3 SP3 and got the same error
Message Edited by brennon.thomas on 01-20-2010 09:26 AM
Message Edited by brennon.thomas on 01-21-2010 10:40 AM
Tags (3)
