requirements
what would be the best or at least acceptble requirements to run EDK, Xilinx to program ML410 or Virtex-4?  as far as CPU speed, memory and disk capacity? my existing system is taking more than 45 min to run EDK samples!
Ramsin
Check this.
http://www.xilinx.com/ise/products/memory.htm
Thnx
Thanks indeed for your help.
